In anticipation of the receipt of an 80 column card for my TC01 (and in the hope it works with my flaky Pipe connection) I am hoping to do some C coding in my tatty.
Can anyone recommend a good C compiler for the tatty? Ideally I need to be able to download a disc image and instructions!
I have seen some public domain images with C (http://www.tatungeinstein.co.uk/front/publicdomain.htm) but no manuals and I have found reference to, for example, Aztec C with manuals (http://www.aztecmuseum.ca/docs/index.htm) but no obvious download...
C for the TC01
C for the TC01
- MikeDHalliday
- Contact:
Re: C for the TC01
The only Aztec C I have seen for CP/M machines is attached.
No idea if it works or not on Albert as I havent tried it, but looking at the archive, it has all the .COM files that you should need.
It might even be too big to fit on a 3" disc?
Regards
Regards
- Attachments
- Aztec-C106d.zip
- (208.32 KiB) Downloaded 743 times
