Compiling Xtal Basic
yevrowl
Post by yevrowl »
In general, there is a source code for a logic game — viewtopic.php?p=1573#p1573
Using EDIP, write the source code to a floppy disk and load it through the MAME emulator.
It works in Xtal Basic 4.2 and 5.0.
However, cannot save it with the SAVE command in any form due to a “Bad Data” error, and have the same problem with compilation.
What could be the reason?
Re: Compiling Xtal Basic
The reason is that mame does not support Einstein disk write operations. Or, that is what the old excuse used to be. I haven't updated my mame for a while, but suspect it's stills the same issue.
yevrowl
Post by yevrowl »
MikeDHalliday wrote: Thu Mar 12, 2026 5:56 pmThe reason is that mame does not support Einstein disk write operations. Or, that is what the old excuse used to be. I haven't updated my mame for a while, but suspect it's stills the same issue.
Perhaps it will work with ColecoDS? Is it worth trying?
Yes, from what I recall is was only mame/mess that did not write to the drive. I am sure there was another emulator I used years ago that wrote back to disk without issue, but I can't remember which. I will have a look at my emulators and see which ones I still have that might do it.
Give colecoDS a go and see what happens. That is one emulator I haven't tried.
yevrowl
Post by yevrowl »
MikeDHalliday wrote: Fri Mar 13, 2026 6:23 amGive colecoDS a go and see what happens. That is one emulator I haven't tried.
As far as can tell, it’s a touchscreen keyboard for the actual Nintendo DS console. Don’t own the console itself, and emulators (DeSmuME and melonDS) don’t support it.
yevrowl
Post by yevrowl »
Compiled it using a CP/M-compatible operating system on MSX. The result, which requires the runtime (xr.com from the compiler package), is attached below.
bt-xbi.7z
(2.15 KiB) Downloaded 150 times
MikeDHalliday wrote: Thu Mar 12, 2026 5:56 pm The reason is that mame does not support Einstein disk write operations. Or, that is what the old excuse used to be. I haven't updated my mame for a while, but suspect it's stills the same issue.
My understanding is that MAME doesn’t support writing to discs because it will lead to the ROMs they distribute getting damaged / messed around with and people ending up with stuff that doesn’t work. Which obviously leads to extra support.
TC-01 + TM-01 + gotek
